1999 Ford Explorer Message Center Blank
RSPETE
I have the Eddie Bauer Edition. The Message Center went blank after the battery was changed. I am wondering if this could be a blown relay, or if maybe the technician may have unplugged by accident a connector near the battery. It was working fine until then. All other displays are fine.
Any ideas?
Apr 1, 2007 at 3:18 PM
MERLIN2021
  • 17,250 POSTS
It sounds like the fuse or the message unt has gone out they had problems with those but to be sure it could just be a fuse (#10) or a bad connection.
Here is the fuse location and the ring diagram along with a guide to help you run a simple test to determine what the problem is.
and
Here is the message wiring diagram (Below)
Cheers
Apr 2, 2007 at 8:01 AM
RSPETE
Yep thanks for the information this site is so great! It was the fuse so I replaced it and everything works Thanks again!
Where can I send money?
Apr 2, 2007 at 9:38 AM
Suggested Repair
Check message center fuse #10 and related connections. Replacing the blown fuse restored the display.
Conversation Summary
A 1999 Ford Explorer Eddie Bauer message center went blank after a battery change while other displays stayed normal. The expert suggested fuse #10, a bad connection, or a failed message unit, and linked fuse and circuit-test guides. The owner found and replaced the fuse, which restored the message center.
