2002 Ford Explorer Odometer Blank
BOTTIS
I have a 2002 Ford Explorer XLT 6 cylinder with 82,000 miles and the digital mileage indicator has stopped showing. For a while the indicator would turn on and off for no reason and finally just stopped showing. I brought it to my local ford service location and they recommended that I replace the entire instrument panel. However, I can't imagine that only part of the panel needs to be repaired. Everything else on the panel works just fine.
Oct 14, 2007 at 9:28 AM
BOOTDOG
  • 665 POSTS
if the cluster is all one unit then yes it'll have to be replaced.
Oct 15, 2007 at 9:43 AM
Suggested Repair
If the instrument cluster is a single unit, replace the entire cluster; the mileage display cannot be repaired separately.
Conversation Summary
The owner of a 2002 Ford Explorer said the digital mileage display flickered and then stopped working while the rest of the instrument panel still worked. A Ford dealer recommended replacing the whole instrument panel. The expert agreed that if the cluster is one unit, the entire cluster must be replaced.
