1999 Ford Explorer Lower Ball Joint Fix
JMORG70
99 Ford Explorer 4wd 4.0 SOHC 110000 miles
The lower ball joints on my Explorer need replacing. The Hayne's manual says you cannot replace the ball joints, you must replace the entire lower control arm. That seems true for the upper arm and not the lower. My question is do I need to remove the torsion bar if I am not removing the lower control arm. I don't have the puller to do it and was hoping to get enough play to just press in the new ball joint. If anyone has done this procedure before any shortcuts would be much appreciated. Thanks
Apr 21, 2007 at 4:23 AM
2CARPRO JACK
  • 11,533 POSTS
If you arent removing the arm , the torsion bar can stay in the truck. You can rent the proper tools to press the ball joint in while the arm is on the truck.
Sep 21, 2007 at 1:05 AM
Suggested Repair
If the lower control arm stays on the vehicle, leave the torsion bar in place. Rent a ball joint press and press the new lower ball joint into the arm while it is still on the truck.
Conversation Summary
The owner of a 1999 Ford Explorer 4WD asked whether the torsion bar must be removed to replace the lower ball joints without removing the lower control arm. The expert said the torsion bar can stay if the arm is not removed and recommended renting a press to install the ball joint with the arm still on the truck.
