1996 Ford Explorer Alternator Failure
KARBONE
96 explorer 4.0 engine 165,000 miles could it be grounds if is which 1 or ones :D
Nov 15, 2007 at 7:01 AM
MERLIN2021
  • 17,250 POSTS
Check the negative cable, at post and block use a volt meter to test it, you should get battery voltage when not cracking and battery -.5volts when cranking, Also if the battery is low or weak in these cars, alternator death can occur!
Nov 15, 2007 at 7:20 AM
Suggested Repair
Voltage-test the negative battery cable at the post and engine block. Expect battery voltage when not cranking and about 0.5 volts below battery voltage while cranking. Also test the battery, since a weak or low battery can destroy the alternator.
Conversation Summary
The owner of a 1996 Ford Explorer 4.0 with 165,000 miles reports four alternators failing in three weeks and asks whether bad grounds are responsible. The expert recommends voltage-testing the negative cable at the battery post and block, and notes that a weak or low battery can cause alternator failure.
