The thing will be running OK then the temp. needle starts creeping into the red and the "check gauge" light comes on. If the truck is left on the needle returns to normal after a few seconds.
A check of the radiator after such an event shows it low on coolant even though the overflow tank is a normal level. The coolant level is checked and OK before the drive.
The cooling system has been flushed, the system has been drained after the flush thinking there is a bubble in causing the "burp".
Pressure checks have been done, radiator cap replaced, thermostat replaced, water pump replaced all to the tune of over $800!!!!! The problem still happens. Everything has been replaced but the blasted raidator!
Don't bother contacting Ford HQ they just say take it to a dealer, (and they wonder why they are going broke)!
I think I will pour in some Bars Raidator Stop Leak and see what happens! The cheapest solution yet!
Any suggestions besides selling my first Ford and buying another dependable Chevy!
Thanks
