2001 Ford Explorer Overheating
KAK1969
I have a 2001 Ford Explorer Sport 87,000 miles and the Engine is running hot. Very hot. The needle goes from C to H in about 5 minutes! The battery light is on, the Check Gauge light is on and the Check Engine light is on. I made sure that there is coolant, although it looked like it was sputtering all over the engine when I raised the hood (green liquid) was all over. I let the car cool down as I was on the highway. It still starts and runs, but gets hot pretty quickly again. Then there is a strange "whirring" noise once I stop the car. This just started last night. What could be the problem? I just got the car in February, so, I am unsure of the upkeep before that
Jul 10, 2006 at 3:05 AM
TAURUSWHEEL
  • 718 POSTS
Well , I wouldn't drive it any further then to the closest reliablre repair shop,, overheating is one of the worst things you can do to your vehicle,, sounds like either a hose or rad burst.. whirring noise might be the fan staying on???
Jul 10, 2006 at 9:36 AM
Suggested Repair
Do not drive the Explorer farther than the nearest reliable shop. Inspect for a burst radiator or coolant hose causing the rapid overheating and coolant spray, and check whether the cooling fan is staying on and causing the whirring noise.
Conversation Summary
The owner of a 2001 Ford Explorer Sport reports that the engine overheats within minutes, with battery, check gauge, and check engine lights on. Coolant was spraying over the engine, and a whirring noise occurs after shutdown. The expert advises limiting driving to a nearby repair shop and suspects a burst hose or radiator, with the noise possibly from a fan that remains on.
