2000 Ford Explorer Overheating
DYSHAUN
I have a 2000 Ford Explorer XLT. There are 86,000 miles on it. I had the thermometer replaced 3 weeks ago, because someone said to. But it is still overheating and cutting off while im driving. My ex-boyfriend used to put water in it for me but i dont know how to do that. The water seemed to help though. I noticed some green stuff leaking out once, but not lately. The AC works fine; the oil was just changed. I saw a man who said it is the radiator. Is that true? Who do i see for this type of service? How much does this type of thing usually cost? I am a single mom of 5; price is a factor. Thanks for your help.
Jun 6, 2007 at 4:29 AM
RUDPRO
  • 224 POSTS
You need to find a good mechanic who can be trusted. Ask him to check for leaks and pressure test the cooling system. It could be something as simple as a hose leaking. Or it could be the radiator or water pump. That's why it's important to find an honest mechanic. Talk with your friends or co-workers to find one. Also, find someone who can check and add coolant until you can take it in. It's bad for an engine to run hot or overheat.
Jun 6, 2007 at 2:42 PM
Suggested Repair
Have a trusted mechanic pressure-test the cooling system and check for leaks. Possible causes include a leaking hose, radiator, or water pump. Keep coolant topped up and avoid driving while the engine is overheating.
Conversation Summary
A 2000 Ford Explorer with 86,000 miles still overheats and shuts off while driving after a thermostat replacement. Coolant was previously added and a green leak was noticed once. The expert advised finding a trusted mechanic to pressure-test the cooling system, since the cause could be a hose, radiator, or water pump, and not to keep driving it hot.
