engine coolant leaking
LMORNEAU
I have a 92 Ford Explorer. I recently thought I had a leak from the water pump. I changed the pump to find that the leak was not the pump but coming from something else. The hoses seem fine but it is still leaking somewhere. I can see the coolant drip down but can't pinpoint where it is coming from. It also makes a hissing sound when hot. Could this be the engine. Thanks in advance for your reply.
Feb 24, 2006 at 1:52 AM
LOVESCARS
  • 359 POSTS
check all heater hoses and if so equiped by pass hose
Feb 24, 2006 at 3:44 AM
HEAVYDUTY
  • 60 POSTS
if your leak seemed like it was the water pump but the pump didn't fix it then you may have a leak in the timing cover that the pump bolts through
Feb 26, 2006 at 10:07 AM
