2000 Ford Explorer Coolant Leak
EVHAL
I have a 2000 Ford Explorer XLT with 146,000 miles and a 5.0L V8 engine. About a year ago a began to notice a very small coolant leak under my vehicle periodically. A small puddle would be visible for a day or two and then the symptom would disappear for several days to a week. Then it would return. After a few months I took it to the dealership and they told me the thermostat housing was cracked. They replaced the housing, thermostat, and houses. Cost $400, but the problem dissappeared. About 6 months later, the problem returned again. After about a month, ironically my radiator cracked and was replaced $368. However, the original problem still exist and seems to be getting worse. It only appears to leak overnight in the garage and sometimes appears to be a large puddle. I crawled under the vehicle again today and it appears that the coolant is leaking almost all around the oil pan where it mounts to the engine. Today the puddle under my vehicle was almost the perfect shape of about half way around the oil pan. I am familiar with engines but not an expert. Is it possible that coolant is leaking from this area? The puddles are always clean and light green in color. I am unable to see any other wet area above the oil pan, just on the exhaust, where fluid has dropped from the oil pan area. Any help that would allow me to avoid another costly visit to the dealership would be great.
May 19, 2007 at 10:11 AM
SERVICE WRITER
  • 9,123 POSTS
With the aid of mirrors and lights, you need to do some close up searching. The water pump is one part that may be an intermittant leak. Keep in mind liquid will follow whatever part it touches and run to places that make it difficult to determine where it's coming from. HAving a pressure tester would make this much easier. If you don't have one, make sure the coolant is full and bring it to temperature and heat is lowing out the vents, looking for any leakage. Shut it off and continue looking. You'll find it.
May 19, 2007 at 12:27 PM
Suggested Repair
Inspect closely with mirrors and lights, since coolant can run along parts and appear to originate near the oil pan. Check the water pump as a possible intermittent source. Use a cooling-system pressure tester if available; otherwise fill the coolant, warm the engine until heat comes from the vents, and look for leaks while running and after shutdown.
Conversation Summary
The owner of a 2000 Ford Explorer with a 5.0L V8 reports an intermittent clean light-green coolant leak that returned after the thermostat housing and radiator were replaced. The puddle appears overnight and follows the oil-pan area, with fluid also dripping onto the exhaust. The expert says coolant can travel along surfaces, recommends close inspection with mirrors and lights, notes the water pump as a possible intermittent leak, and advises using a pressure tester or checking for leaks after the engine reaches operating temperature.
