1992 Ford Explorer Coolant Leak
LMORNEAU
I have a 92 Ford Explorer. I recently thought I had a leak from the water pump. I changed the pump to find that the leak was not the pump but coming from something else. The hoses seem fine but it is still leaking somewhere. I can see the coolant drip down but can't pinpoint where it is coming from. It also makes a hissing sound when hot. Could this be the engine. Thanks in advance for your reply.
Feb 24, 2006 at 1:52 AM
LOVESCARS
  • 359 POSTS
check all heater hoses and if so equiped by pass hose
Feb 24, 2006 at 3:44 AM
HEAVYDUTY
  • 60 POSTS
if your leak seemed like it was the water pump but the pump didn't fix it then you may have a leak in the timing cover that the pump bolts through
Feb 26, 2006 at 10:07 AM
Suggested Repair
Check all heater hoses and the bypass hose if the vehicle is equipped with one. If coolant still appears to come from the water pump area after the pump was replaced, inspect the timing cover where the pump bolts through for a leak.
Conversation Summary
The owner of a 1992 Ford Explorer replaced the water pump after a coolant leak, but the leak continued. The hoses look fine, coolant drips from an unclear source, and the engine hisses when hot. An expert advised checking all heater hoses and the bypass hose if equipped. Another reply suggested a possible leak in the timing cover where the water pump bolts through.
