2003 Ford Explorer Door Ajar Light
DOUGTHOMAS0220
The "Door Ajar" light and chime occassionally come on when my 2003 Ford Explorer with 70,000 miles is running. I have narrowed this down the the driver's door. Where is the door sensor located on this vehicle?
Aug 19, 2007 at 1:34 AM
SERVICE WRITER
  • 9,123 POSTS
Try to spray the door latch with a thin lubricant such as wd-40. Open and close the door5-6 times and spray it again. Repeat a few more times.
Aug 19, 2007 at 1:43 AM
Suggested Repair
Spray the driver's door latch with a thin lubricant such as WD-40, then open and close the door several times and spray again. Repeat this a few more times.
Conversation Summary
The owner of a 2003 Ford Explorer with 70,000 miles reported an occasional Door Ajar light and chime while running and had narrowed it to the driver's door, asking where the door sensor is located. The expert recommended lubricating the door latch with a thin lubricant such as WD-40 and cycling the door several times, repeating the process.
