Brake lights will not turn on when brake is pressed
CMOWENSRN
  • FORD EXPLORER
My brake lights will not turn on when I press the brake. The brake lights turn on when the headlights are turned on, but the brake lights will not glow when I press the brake peddle down. I am draving a 2002 Ford Explorer XLT V6 with 88k miles standard engine no modifications. Past repair history= the only repair I have had to make was a window switch that wouldnt operate correctly on the left drivers side window other than that the car has been great.
Friday, June 22nd, 2007 AT 11:05 AM
MERLIN2021
  • 17,250 POSTS
Try checking the fuse, then the stop light switch at the brake pedal.
Saturday, June 23rd, 2007 AT 3:29 PM
CMOWENSRN
Where is the fuse that controls the brake lights. Brake lights not working when brake pressed. The brake lights will come on when the head lights are turned on.
Sunday, June 24th, 2007 AT 7:44 PM
NEILCAT
The fuse box is under the dash on the drivers side
Tuesday, July 3rd, 2007 AT 9:00 PM
