1996 Ford Explorer P0402 EGR Flow
GEORGERR
  • 9 POSTS
Anyone care to venture a guess as to where the EGR valve is located on this engine, and whether it's the valve or sensor that is setting a PO402 'excessive EGR flow fault code'???
Thanks
May 5, 2007 at 3:45 AM
MERLIN2021
  • 17,250 POSTS
If you look for the small flex tube running off the exhaust, the egr is at the end of it bolted to the throttle body...excessive flow could be a stuck valve or bad EGR solinoid.
May 6, 2007 at 12:35 AM
GEORGERR
  • 9 POSTS
Thanks Merlin. I found it. I'm new to these electronic everythilng engines and paranoid about making mistakes, so I proceed very cautiously.
May 6, 2007 at 2:59 AM
Suggested Repair
Locate the EGR valve at the end of the small flex tube from the exhaust, where it bolts to the throttle body. For P0402 excessive EGR flow, check for a stuck EGR valve or a faulty EGR solenoid.
Conversation Summary
The owner of a 1996 Ford Explorer 5.0 asked where the EGR valve is located and whether the valve or a sensor was causing a P0402 excessive EGR flow code. The expert said the valve is at the end of the exhaust flex tube, bolted to the throttle body, and that excessive flow could come from a stuck valve or a bad EGR solenoid. The owner later confirmed finding the valve.
