1994 Ford Explorer Dies at Idle
EXPLODER94
My 1994 Ford Exploer XL Manual with 132000 dies when I let it idle. This problem does not always happen. My Check engine light had been on for a year before this problem occured and my mechanic said the EGR code he got was harmless and when I wanted I could do the work myself. When the idle problem started I got a full tune up and got the codes read again. I got codes for the MASS sensor and the EGR valve. I replaced the EGR and cleaned the MASS along with the Idle Air Control Valve. I did not get any codes for the idle componetes or the Oxy sensor. My check engine light is still on and I still recive some EGR codes. Should I replace the EGR solinoid next or will that not solve my idel problem? I realize I should take care of the check engine light problem, however the idle is a more pressing matter.
Aug 12, 2007 at 6:13 AM
  • 75,988 POSTS
[quote:46c5bdbc60="exploder94"]My 1994 Ford Exploer XL Manual with 132000 dies when I let it idle. This problem does not always happen. My Check engine light had been on for a year before this problem occured and my mechanic said the EGR code he got was harmless and when I wanted I could do the work myself. When the idle problem started I got a full tune up and got the codes read again. I got codes for the MASS sensor and the EGR valve. I replaced the EGR and cleaned the MASS along with the Idle Air Control Valve. I did not get any codes for the idle componetes or the Oxy sensor. My check engine light is still on and I still recive some EGR codes. Should I replace the EGR solinoid next or will that not solve my idel problem? I realize I should take care of the check engine light problem, however the idle is a more pressing matter.[/quote:46c5bdbc60]
If you have a problem with the EGR system it willl do that. If the EGR opens when not needed it will create a massive vacuum leak.
Aug 12, 2007 at 10:11 AM
Suggested Repair
Diagnose the EGR system so the valve does not open at idle. Unwanted EGR flow acts like a large vacuum leak and can stall the engine; check the EGR control/solenoid and related vacuum lines rather than only replacing parts.
Conversation Summary
A 1994 Ford Explorer with about 132,000 miles intermittently dies at idle. The check engine light had been on with EGR codes, and later MAF and EGR codes appeared. The owner replaced the EGR valve, cleaned the MAF and idle air control valve, and still has EGR codes. The expert says an EGR system fault can cause this if the valve opens when it should not, creating a large vacuum leak.
