Blend door actuator?
EXPLORER02
  • 7 POSTS
Joe do you have any idea where the heater core speciffically is I cant find it
Friday, December 13th, 2019 AT 1:26 PM (Merged)
  • 110,053 POSTS
If you look under the hood (firewall), you will see where the heater hoses attach on the firewall. They attach to the heater core. It is on the inside of the vehicle where the hoses attach.
https://www.2carpros.com/forum/automotive_pictures/249084_5_80.jpg
Let me know if you find it.
EXPLORER02
  • 7 POSTS
Joe I think I can see it but what door covers it to flow heat, I dont see anything in front of it
EXPLORER02
  • 7 POSTS
Joe I think I can see it but what door covers it to flow heat, I dont see anything in front of it[/quote:ee8e3f8a62]
ok joe I got into the dash and everything tried moving around the vent doors to try and circulate heat, still no heat anymore ideas you might have
  • 110,053 POSTS
I need you to check something. With the engine at operating temp and the heater on, do both heater core hoses get hot?
EXPLORER02
  • 7 POSTS
Yes joe both are hot.I also checked the coolant flow valve that is also operating correctly. I have no coolant leaking from the heater core or anything
  • 110,053 POSTS
The only thing left is the blend air door. It must not be opening toward the heater core. If the heater core hoses are hot, then the core must be hot. Something is stopping the air from passing over it. That would be the blend air door. That is all that is left.
Try checking it one more time.
