COULD YOUTELL ME WHERE THIS DOOR IS LOCATED? DO I NEED TO REMOVE THE DASH
Nov 22, 2008 at 5:58 AM
DAVE H
✓Experienced Mechanic
yes .. i'm afraid you have to remove the dash to remove this part ..
Temperature Blend Door Actuator
The temperature blend door actuator:
Is located on the heater core and evaporator core housing.
Moves the temperature blend door on command of the temperature control switch.
Contains a reversible electric motor.
