Engine overheating
JOARLYNJALEX1
  • 2002 FORD EXPLORER
  • 3.4L
  • 6 CYL
  • 4WD
  • 102,000 MILES
Car overheated and white smoke coming out of the muffler.
Tuesday, August 28th, 2018 AT 6:19 PM (Merged)
  • 109,885 POSTS
I'm glad you got it fixed. Let us know if you have questions in the future, and we would appreciate you telling friends about the site.
Take care, and thanks for using 2carpros. Com,
HMAC300
  • 48,601 POSTS
Have coolant system pressure tested for a head gasket leak.
MELON1981
  • 4.6L
  • V8
  • 4WD
  • 101,000 MILES
Hello, I just bought this. And it overheats and dies. My husband changed the thermostat and it is still doing this. It overheats in no time. Could u please help me. Thanks
CARADIODOC
  • 33,916 POSTS
What does "in no time" mean? A minute? An hour? Slow, city driving? On the highway? What are the symptoms? Are you simply going by the gauge on the dash or is there something else that tells you the engine is too hot?
When you think the engine is too hot, feel the upper radiator hose near the radiator. It should be too hot to hold onto for very long but it shouldn't burn you. If the hose is relatively cool, suspect the thermostat isn't opening, and that would most commonly be due to a leaking cylinder head gasket. Combustion gases can pool under the thermostat and prevent it from opening. They have to be hit with hot liquid. Hot air won't do it. There's a chemical test your mechanic can perform at the radiator to test for a leaking head gasket. That test just takes a couple of minutes.
When the engine stalls, what do you have to do to get it restarted? Has anyone checked for diagnostic fault codes?
MELON1981
Thanks for answering me. It takes 5 or 6 mins to get to normal operating temperature. Then less than a second it shoots to hot. Yes the diagnostics has been done it said #2 cylinder misfire. And overheating. It starts back up when it dies also.
CARADIODOC
  • 33,916 POSTS
The place to start is by connecting a scanner to view live data and see exactly what the coolant temperature is. If it's normal, around 200 degrees, but the temperature gauge is reading too high, suspect the instrument cluster. The engineers at Ford have turned the really reliable cluster into another computer module, so now we have all kinds of computer-related problems we never used to see.
Your mechanic will also watch that coolant temperature to see if it suddenly jumps up too high. If it does, there could be a problem with the temperature sensor or its wiring, but those should both be down pretty far on the list of suspects.
If we were to assume the misfire and overheating are related, the leaking cylinder head gasket is a good suspect. Your mechanic will perform a test at the radiator with the engine warmed up and running. That involves drawing air from the radiator through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If combustion gases are present, the liquid will turn bright yellow.
YSNDRS
  • 1999 FORD EXPLORER
  • 6 CYL
  • 165,000 MILES
My 99 ford explorer was running fine until the next morning when the temperature went down. It ran hot and shut off. It has not done this before. Would like to know what is the problem.
What is it doing? Cranking over and w/n start or just won't crank over at all/nothing when you turn key to cranking position?
CJ MEDEVAC
  • 11,005 POSTS
How quick did it run hot, when you started out?
How long did you run it while OVERHEATED (HONESTLY, not trying to "Impress Me". Mine is running!). We need real honest info, in order to assist you, We do not perform miracles, With "Made Up Stuff".99% say they shut it down immediately, 1% have their head in their hands, cause they know what they done.
Coolant / Antifreeze Correct MIX. Not guessing the ingredients (like you cook), but really installed at minimum, 50% Antifreeze/50 Water? (Before it was poured in)
How much water did I take to refill it, after the "Incident"?
The Medic
KIMGW
  • 2005 FORD EXPLORER
  • 6 CYL
  • 119,000 MILES
If an engine overheated after driving 15 miles at 75 mph in 2nd gear but was not driven more than a mile after warning came on, is it possible it could be an easy fix? Thank you for your time.
CARADIODOC
  • 33,916 POSTS
The fix is to get a driver who knows better than to seriously abuse an engine like that. What else do you think there is that needs to be diagnosed? Any engine can be expected to run hot after doing that, and even if it runs once it's cooled down, the temper will have been removed from some hardened parts, connecting rod bolts will have been stressed, and things like that.
To get an idea of the effect over-revving an engine has, a $100,000.00 NASCAR engine runs at around 8,000 rpm, and they hope it will hold up for 500 miles. A Chrysler 426 Hemi NHRA dragster engine develops over 3,000 horsepower and runs at 10,000 rpm, and it gets rebuilt after every race that lasts less than four seconds. Diesel engines typically run at very low speeds and in big trucks they last almost forever.
Your engine was designed to haul you around for 200,000 miles, but there's always a trade-off. To achieve the reliability we demand, we have to give up power, high speed, or some other characteristic. You can't run it outside the limits it was designed for for very long.
EXPLODEROWNER
  • 2001 FORD EXPLORER
  • V8
  • AWD
  • 100,000 MILES
The engine overheated due to a ruptured hose and sprayed coolant inside the engine. What is the likelihood of a head gasket being affected when this takes place?
BLACKOP555
  • 10,371 POSTS
Chances are no gaskets have been ruined during the process, unless the engine was badly overheated and the headgaskets blew, causing the ruptured hose.
NDEERINWATER
  • 6 CYL
  • 141,000 MILES
My car has been overheating for the last month. We have changed the radiator the temp gage the water pump and the heater core. Why is my car still over heating?
  • 109,885 POSTS
Hi:
Did you replace the thermostat? Also, is the engine running good?
NDEERINWATER
Yes we replaced the thermostat. The engine was running just fine. My husband changed the oil and he said that there was no water in it so we dont think its got a cracked head. But I have noticed that when I stop it acts like the timing is off it like shaking.
Tuesday, August 28th, 2018 AT 6:20 PM (Merged)
DAVE H
  • 13,384 POSTS
I would have the cylinders compression tested to check the headgasket. Are you getting white smoke from exhaust or OIL in coolant tank? The shaking could be a sign of water on plugs causing slight misfire
NDEERINWATER
No there was no oil in the overflow and no smoke that I can see.I will have those things checked. Thank you very much and have a happy new year.
