2005 Ford Explorer Thermastat Housing
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLDALY
My daughter drives this vehicle. Teenager... The engine overheated a month ago and I put in 1 gallon of antifreeze and some water. Watched closely for a week all was ok. Then my daughter called to say it overheated. Went to look and I could smell anti-freeze but there was smoke coming from around the manifold. Radiator and overflow container had antifreeze overflow down about 4 inches. Took into Firestone and they pressure tested. Looks like there is a leak in the Thermostat Housing. They also did not rule out the plastic manifold over the engine. Looks like Thermostat housing is OEM and prices out at around $139. This includes top and bottom plus gaskets and replacement thermostat. How difficult is this to do myself? I have a minor mechanic ability. Total cost with labor and flush is $500+. What do you recommend?
Jan 9, 2010 at 2:04 AM
  • 110,246 POSTS
You should be fine if you have mechanical ability. It is just a matter of draining the radiator and a couple bolts that hold the t-stat housing.
If you run into trouble, let me know.
Jan 9, 2010 at 5:21 PM
