Based on the codes you provided, I feel the problem is related to the camshaft position sensor and not the crankshaft position sensor. The codes indicate a misfire on cylinder 6, a misfire within the first 1000 revolutions of the engine after starting and a camshaft sensor failure, which leads me to the P0340. That indicates a camshaft position failure bank 1. That will cause the misfire (p0306) and the P0316 to set.
With that, and I can't be 100% certain without being there, it seems the camshaft position sensor is causing all of the codes.
With that in mind, I would start with that sensor. Here are the directions for replacing it. The attached picture shows its location.
___________________________
CAMSHAFT POSITION (CMP) SENSOR
REMOVAL
1. Disconnect the battery ground cable.
2. Remove the components in the order indicated in the illustration and table.
INSTALLATION
1. To install, reverse the removal procedure.
____________________________
Now, on your vehicle has two sensors. You need to replace bank 1, which is on the side of the engine which has cylinder 1. If you are facing the engine from the front of the car, it will be the left side. I attached a picture of cylinder locations. The arrow points toward the front of the vehicle.
It will be located below the valve cover as indicated.
Images (Click to enlarge)
Dec 20, 2018 at 11:00 AM
