2003 Ford Explorer REALLY NEED HELP!!! Howling Noise 03 Exp
133,500 MILES • 6 CYL • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
I have 03 Explorer I just got the oil changed and they told me that my differential was leaking. I have been hearing a howling noise from rear end when i'm at cruising speed when i let of accelerater it stops. Will changing the gear oil fix that?
Feb 27, 2010 at 10:09 PM
  • 110,251 POSTS
Try this first. While driving, safely turn left and right. Does it change the sound?
Also, did they at least refill the differential for you?
Feb 28, 2010 at 10:32 PM
POCOLACHRISTIAN
  • 62 POSTS
I can't really tell if the sound changes but I know when i reach around 50mph you can hear it real bad it seems like right side then when i hit 70mph you hear it in left side more.
Feb 28, 2010 at 11:25 PM
