2003 Ford Explorer howling noise coming from rear when crus
2003 FORD EXPLORER
133,500 MILES • 6 CYL • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
I have a ford explorer and i noticed whe I hit 50-70mph i start hearing a howling sound from rear end. When i let off gas it quits. I recentlly got my oil changed and they said my differental was leaking. If I get that fixed and change gear oil will that do the trick or is my rack and pinion or something else. Any Ideas?
Feb 27, 2010 at 3:18 AM
  • 110,244 POSTS
The noise from the differential may go away by having it serviced; however, it may stay the same. For now, make sure the differential is full.
The reason I say the noise may not go away is because you may have already done the damage to a bearing. If you fill the differential and the sound still doesn't go away, replacing the seal and refilling it won't change it. The mechanic will need to identify where the noise is coming from.
Feb 28, 2010 at 11:59 PM
POCOLACHRISTIAN
  • 62 POSTS
Is that a big job if the damage is done. Replacing a bearing. I just bought the car so I really don't know how long it's been doing it. Is that something anyone could do or should i take it to ford dealer. Thank You very much
Mar 1, 2010 at 1:17 AM
  • 110,244 POSTS
It is hard for me to say. It could be as simple as setting backlash or major part could need replaced.
I wish I could be more specific, but I would need to remove the differential cover and check if that is it and what it is.
Mar 1, 2010 at 5:15 AM
POCOLACHRISTIAN
  • 62 POSTS
Thank You for your help.
Mar 1, 2010 at 7:33 AM
  • 110,244 POSTS
You're welcome, but I don't feel like I helped too much. Let me know what they find before they do any work so I can direct you.
Thanks for using 2carpros.com.
Mar 1, 2010 at 8:05 AM
POCOLACHRISTIAN
  • 62 POSTS
Can you tell if there is any damage just by taking cover off and inspecting. Could axle bearing be causing the noise or is just probably the differential. Thank You
Mar 1, 2010 at 3:33 PM
  • 110,244 POSTS
You may find some steel filings in the differential if you remove the cover. And yes, it could be a bearing.
Mar 1, 2010 at 10:23 PM
