2003 Ford Explorer Power Windows
BUTTERNUTS
  • 2003 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 85,000 MILES
The power windows suddenly stopped working at all doors on my 2003 Ford Explorer. I changed the circuit breaker (#62) per the owners manual with no result. The parts guy told me that the "main power window switch" at the drivers door goes bad frequently on these vehicles. I purchased a new switch and need to know how to remove the old one and install the new one without tearing my door apart.
Sunday, April 4th, 2010 AT 7:47 AM
DAVE H
  • 13,384 POSTS
Removal and Installation
Remove the components in the order indicated in the following illustration and table.
Fig. 162: View Of Removing Window Control Switch
https://www.2carpros.com/forum/automotive_pictures/266999_exp_8.jpg
To install, reverse the removal procedure.
Item 1: Window Control Switch Bezel Removal Note
Lift the front of the window control switch bezel upward to release the front hold-down clip.
Slide the window control switch bezel forward to release the rear tab.
Sunday, April 4th, 2010 AT 8:32 AM
