Window went down (auto-open) but will not close. All other windows work fine. Did note that the auto window lock does not work. All fuses seem to be good. How can I check to see if the motor is getting a signal from the switch without removing it? Do I have to remove the door panel to remove the motor? If so, how do I remove the panel?
Apr 30, 2008 at 11:55 PM
