2003 Ford Explorer Ac Problem
RIDER1008
Hi
I have a 03 ford explorer with 60,000 on it. I'm having a problem with ac coming out cold on the right vents and warm on the left. The temperature seems to rise from right to left. I just moved to phoenix,az and refilled my ac with the refrigerant 134a and it seemed to last about 3 months. I'm not sure how long the refills are suppose to last but it seemed to go out pretty quick. Today I refilled the refrigerant with a refill that has leak sealer but it doesn't seem to fix the problem with the left vents being warmer. Any ideas on what my problem might be?
Aug 23, 2007 at 1:21 PM
RIDER1008
Thanks for the informative and fast response. I forgot to mention that when I change the speed of the vents from 1-3 it stays the same until I change it to 4 then it goes full blast. I haven't tried your remedy yet but will get back to you if it fixes my problems.
Aug 26, 2007 at 10:25 AM
