2003 Ford Explorer
LILSOPHIA
  • 2003 FORD EXPLORER
  • 6 CYL
  • 90,000 MILES
Hello
the a/c is not blowing cold air. I checked the feron and it was low so I had added ferom but it still did not work. A few weeks later the feron seemed to be low. Which is wierd because I had not used the a/c. Could there be a link? Is this a huge problem or can I fix myself?
thank you
Wednesday, June 25th, 2008 AT 3:19 PM
BMRFIXIT
  • 19,053 POSTS
Freon 134A does not go low if you use the AC or not
it should be a sealed unit
you need to check for leak
may I suggest having a qualified tech take a look at it as they have to add dye to the system and check for leaks
good luck
Wednesday, June 25th, 2008 AT 7:44 PM
Related Air Conditioner Not Working Content
Fix an Air Conditioning Not Working Video
VIDEO
