Fuel filter location I need to replace it?
RATSO123
  • 2002 FORD EXPLORER
  • 4 CYL
  • 4WD
  • 40,000 MILES
How do you R&R fuel filter (2 hoses in 1 out? Which is which?) What tools do you need & are there any resets or overides that need to be performed?
Wednesday, October 7th, 2020 AT 1:20 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
No resets required. basic mechanic tools (wrenches , socket etc..)
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_762.jpg
GULF36
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 13,700 MILES
Wanted to know were the furl filter is located and is it an easy change?
Wednesday, October 7th, 2020 AT 1:21 PM (Merged)
It's located just under the driver's seat on the frame rail.
You will need a 13mm socket/wrench, and a flat screwdriver to undo the supporting bracket/clamp respectively. A special tool is required on most models to release the fuel line; however, it is relatively cheap and can be obtained at your local parts store. It is used like a quick-disconnect to undo the fuel line.
Once disconnected the new filter is just snapped on the line with ease and the safety clips can be reinstalled and thus the filter remounted.
