Yes it does, but which engine do you have so i can send a correct picture of the unit and location?
Jan 22, 2017 at 7:24 PM
SAXYBILL1
MEMBER
I have a 2007 Explorer with a 4.0 engine.
Thanks
Jan 23, 2017 at 1:09 AM
STEVE W.
✓Experienced Mechanic
No it actually does not. See my reply on your no start question about it. Fuel pressure is set by the fuel pump module by controlling the ground side of the pumps power. No stand alone regulator involved.
Jan 23, 2017 at 2:21 AM
i stand corrected, i was thinking about the pressure and temp sensor..........
Jan 24, 2017 at 7:03 PM
STEVE W.
Yeah it would actually be an easier system if it had a regulator instead of the convoluted mess they used.
Jan 25, 2017 at 3:58 AM
SAXYBILL1
MEMBER
i agree, would have been much easier if it had a regulator. i did order a pressure control module, hopefully, that will fix it. anything unusual i need to know before i install this.
thanks
Jan 25, 2017 at 3:40 PM
STEVE W.
Did you watch the video I posted to the other thread? The pump driver is basically plug and play.
