2002 Ford Explorer Windows will not roll down.
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHI1RAY
I have had the driver side window regulator replaced in my 2002 ford explorer 2 times within the last two years, the last one being 2 months ago. Now none of my windows will roll down. Does one motor control all four window? If not, what could be the issue. Thanks!
Apr 24, 2008 at 8:46 AM
TTRAN
  • 45 POSTS
Check the voltage goes in your control panel switch. It seems to me that you have a problem with the voltage at this master control switch or the fuse is blown.
Tony
Apr 28, 2008 at 9:28 AM
FLEXY5
  • 512 POSTS
If you inspect the switch, make sure you have power and ground leaving the switch. There should be a main power in and a main ground in. Then there should be two wires for each window. They alternate polarity based on the switch up or down position. If it is not reversing polarity on the switch for the bad window, then you may have a bad switch. If it is, pull the door panel off and check for the same thing at the window motor plug. You may have a broken wire in the door jamb. It tend to be the driver door jamb as it is used the most. If you have any further questions, feel free to ask.
Apr 28, 2008 at 1:45 PM
