2002 Ford Explorer window regulator pass side front
COX3406
Interior problem
2002 Ford Explorer Two Wheel Drive Automatic
Hi guys,
Any tips for the above mentioned job, its for my new girlfriend and I want to do well. I am a pretty good 'shade tree" so I think I can save her a ton money if I can do this for her. I plan on obtaining parts from "PullApart" if I can find them, or should I use new. It is the front passenger side, all aid is apperciated. Thank you for your time, Mark in Tennessee
Jul 18, 2010 at 10:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
raise the window glass to half open. remove door trim panel. remove inside glass weatherstrip. remove watershield. disconnect lock rod at the latch assembly. remove bolts that attach glass to regulator (raise window to full up for this). support window. disconnect window motor connector. disconnect motor and regulator assembly from door frame. remove through door opening.
Jul 18, 2010 at 1:32 PM
COX3406
[quote:2560a6bbc7="bluelightnin6"]raise the window glass to half open. remove door trim panel. remove inside glass weatherstrip. remove watershield. disconnect lock rod at the latch assembly. remove bolts that attach glass to regulator (raise window to full up for this). support window. disconnect window motor connector. disconnect motor and regulator assembly from door frame. remove through door opening.[/quote:2560a6bbc7]
Works great and new gal happy, used new parts from Advance Auto, 87.00 for regulator and motor, same day delivery,
Thanks.....Mark and Sharon in Tennessee
Jul 19, 2010 at 12:48 PM
