2002 Ford Explorer Window regulator
TPOLSGROVE
  • 2002 FORD EXPLORER
Interior problem
2002 Ford Explorer Two Wheel Drive Automatic 185000 miles
How do you remove door panel in order to replace window regulator?
Sunday, July 25th, 2010 AT 6:59 AM
EDWARD.S
  • 166 POSTS
Hi, First Remove any Screws, Some Screws Are Hidden Under Covers. If You See A Round Cover Carefully Pry It off And remove Screws Remove Any Screws That Are Under The Arm Rest. On Some Cars They Put Screws Under The Window Switch, Or Behind The Door Reflector. Carefully remove Them. Now Get A Door Panel Tool, And start at The bottom, Put It Out Just Enough To see The Plastic Clips. Now Put the Door panel Tool Under The clips And Pull Outward. Carefully Try Not to Break The Any Clips. Some May Fall Off, But Can Be Reattached. Remove All the clips, Lift Up To Remove The door Panel. Now Carefully Remove Plastic Covering. You Will Need To Drill Out the rivets And Unbolt The two Screws From The Glass. Wear Heavy Gloves, Metal In Doors Is sharp, Will cut you. You Will Need a large Rivet Gun And Large Rivets To Secure Regulator, To the door.
Hope This Helps You,
Good Luck
Edward S.
Sunday, July 25th, 2010 AT 7:55 AM
