I had the identical problem. Guess what, I pulled back the rubber grommet where the wire harness runs from the door to the inside of the car where after years of opening and closing the door, a wire finally broke. I found a broken wire which when I used an alligator jumper clip from one end to the other, the windows worked. So, I took it to a repair shop and they spliced it together. My hands were too big to do the job, but you might be able to if you find the same problem.
SPONSORED LINKS
Tuesday, August 25th, 2009 AT 8:38 PM
