2002 Ford Explorer driver side window
BRAVOCESAR
Electrical problem
2002 Ford Explorer 62000 miles
my driver side window went down and is stuck. the other windows work fine. when i press the button for the driver window there is a clicking noise. i've heard it could be the switch or the motor. what are your thoughts?
thank you
Mar 30, 2008 at 8:53 AM
FLEXY5
  • 512 POSTS
Remove the door card and use a volt meter or a test light to check for power at the motor. If you have power in both switch positions, then replace the motor. If you are using a volt meter, one direction will read negative voltage, which is normal. If you do not have voltage present, start looking at the switch. Check for proper operation of the switch and if that is ok, you may have a broken wire. If it's a wire problem, they are common to break at the door jamb. Post back with what you find or any other questions you may have.
Mar 30, 2008 at 11:55 AM
