2002 Ford Explorer A/C Clutch
2002 FORD EXPLORER
6TRACYC
Air Conditioning problem
2002 Ford Explorer 6 cyl Automatic
My a/c quit blowing cold yesterday. I figured it was freon so I added it and it's still blowing hot air. I checked the relay for the a/c clutch and the fuses and everything is still good there. What is the next point of interest to solve this problem? HELP please...I need the a/c working asap!!!!
Sep 11, 2010 at 6:32 AM
  • 110,240 POSTS
Is the clutch engaging?
Sep 12, 2010 at 3:22 PM
6TRACYC
No. It doesn't turn on when I turn the a/c on. It is blowing hot air but no a/c
Sep 13, 2010 at 2:32 AM
  • 110,240 POSTS
If the freon is fully charged and the compressor isn't engaging, I need you to check if the clutch is getting power.
Let me know what you find.
Sep 13, 2010 at 5:04 AM
6TRACYC
Ok...so I took it to an automotive shop and I was told I have a "scroll compressor." In addition to that, the compressor exploded and needs to be replaced and possible the condenser if it can't be flushed. Can I replace it with a regular compressor or does it have to be a "scroll compressor?'
Sep 13, 2010 at 5:27 AM
