2002 Ford Explorer
JAYSTN62
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 76,000 MILES
My drivers side approach light does not come on when I unlock the door. The passenger side still works. I was wondering what is the proper procedure for replacing the bulb if that is the problem.
Thursday, December 11th, 2008 AT 6:12 PM
RACEFAN966
  • 5,029 POSTS
Ok it looks like there should be two screws that hold the lens on or the lens pops out can't really tell the pic. Replace the bulb and put the lens back on thats it. It should be a bulb as the other side works and they are both controlled by the GEM Module. Hope this helps. Thanks.
Thursday, December 11th, 2008 AT 11:02 PM
