2002 Ford Explorer
JCEE
  • 2002 FORD EXPLORER
2002 Ford Explorer 6 cyl Four Wheel Drive Automatic
HOW TO REPLACE FUEL PUMP
Saturday, April 18th, 2009 AT 7:09 AM
  • 109,755 POSTS
Hi:
The fuel pump is in the fuel tank. Disconnect the battery, remove the fuel tank straps and lower the tank. On the top of the tank you will see the sending unit attached to the tank. Remove it, pull the pump out, replace it with the new one and reverse the sequence.
Sunday, April 19th, 2009 AT 4:46 PM
