i have a problem with a cylinder that has spark and fuel and it will not fire. the compression is 150psi. i have changed the coil pack the plug and wire and the injector. i checked the vacuum lines and they are good. i have checked the resistance on all the elec. and the cylinder still will not fire. any help will be appreciated.
May 17, 2010 at 1:58 PM
