Programmming of key does not require any scan tools.
Is your fob the one shown in diagram and is the procedure you have tried the one in chart?
Wednesday, January 6th, 2021 AT 2:12 PM
(Merged)
JOSEPHLANG
MEMBER
No where in my questiom did I ask about fobs im talking about transpoonder key programming
SPONSORED LINKS
(Merged)
KHLOW2008
MECHANIC
Sorry, my bad for misinterpreting your question.
New Generation Star (NGS) tester and Ford Service Function (FSF) card must be used if the two programmed key method does not work.
(Merged)
SCATR001
MEMBER
1 POST
2000 FORD EXPLORER
6 CYL
2WD
AUTOMATIC
170,000 MILES
My father in-law had a new radiator installed, when he brough it home the check engine light came on. I pluged in my code reader & the codes are p0171 & p0174 ( bank 1 & 2 too lean). I tried to find a vacuum leak but was able to find it. Is there something else I should be looking for?
(Merged)
MECHANIC
The lean code usually is exactly what you mentioned, a vacuum issue. I would continue checking that. Also, make sure the O2 sensors are connected and the coolant temp sensors are connected.
