2000 Ford Explorer Codes With No Clue
SKEVANS
  • 2000 FORD EXPLORER
  • 6 CYL
  • 151,000 MILES
Im runnging lean in bank 1 and bank 2 - I read before this is resulting from maybe a fuel pump change - I cant afford to have a diagnostic with Ford - is anyone familiar with this code?
please help.
Monday, February 11th, 2008 AT 11:02 PM
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (Use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (Try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
Monday, February 11th, 2008 AT 11:10 PM
SKEVANS
Thanks for the response. I know for SURE it isn't the EGR valve and we checked everything for leaks - we can't see any external leaks. But I really appreciate such a speedy response and we'll go through what you gave - I have a specific code that starts 14 but. I don't have all of it with me right now.
Monday, February 11th, 2008 AT 11:33 PM
Is it one of these
P1400 - DPF EGR Sensor Circuit Low Voltage Detected
P1401 - DPF EGR Sensor Circuit High Voltage Detected
P0401 - EGR Flow Insufficient Detected
P0402 - EGR Flow Excessive Detected
Monday, February 11th, 2008 AT 11:37 PM
