2000 Ford Explorer clutch
RCFLYER
  • 2000 FORD EXPLORER
Transmission problem
2000 Ford Explorer 6 cyl Two Wheel Drive Manual
i had a brand new clutch put in last nite by a good mechanic new slave cylinder, new flywheel, ran great all the way home, got in the truck this morning and no clutch, all the way to the floor, it wont even go nto gear, could it be that they did not bleed the slave cylinder correctly
Saturday, February 13th, 2010 AT 12:45 PM
  • 109,885 POSTS
If it worked when it was first done, he bled it properly. Have him recheck his work to make sure something isn't leaking. I strongly feel it has to do with the slave cylender and hydralic pressure.
Sunday, February 14th, 2010 AT 2:38 PM
