2000 Ford Explorer Clutch
2000 FORD EXPLORER
123,000 MILES • 6 CYL • 2WD • MANUAL
SIDEBERNIE
I have a 2000 Ford Explorer manual transmission and the clutch does not have much pressure. It engages about an inch or so from the floor. I know its hydraulic and can't be adjusted. I was looking for the fluid reservoir to check the level and can't find it. Is it connected to the brake fluid reservoir?
The car still rune and engages fine but is slowly getting weaker.
Thanks,
Bernie
Jul 21, 2009 at 3:36 PM
  • 110,194 POSTS
It should be on the firewall (driver's side).
Let me know if you find it.
Jul 21, 2009 at 10:57 PM
SIDEBERNIE
Thanks you. I found it.
Jul 22, 2009 at 6:48 PM
  • 110,194 POSTS
I'm glad you found it. Les us know if you have other questions in the future, and thanks for using 2carpros.com
Jul 22, 2009 at 10:13 PM
