2000 Ford Explorer Hard Start
NONA
in the morning even in good weather I have to oump & hold the accelorater to get it started takes a long time some mornings. I put fuel injection cleaner in my gas but I don't know whats wrong. I have been taken advantage of by garages to many times i just can't afford to go back. There is only 100,000 klm on my truck . Can you please help
Jan 11, 2007 at 11:15 PM
INDYUKE
  • 416 POSTS
Is your check engine light on? How does the truck run once you do get it started? Let us know.
Jan 12, 2007 at 7:58 AM
NONA
Yes the check engine light is on. After the truck gets started it runs great. I went for a diagnostic $98. later they said they didn't know why it was on.
Jan 14, 2007 at 10:47 PM
INDYUKE
  • 416 POSTS
If the check engine light is on, there is a definate reason it's on. The check engine light is an warning lamp to let you know that an emission component is malfunctioning or wearing out, both of which can adversely affect your vehicle's operation. When you scan the computer for fault codes that the check engine light indicates are there, it will point you towards a malfunctioning component or towards a sensor that is accurately reading a certain engine parameter that is falling outside the manufacturer's specifications, i.e., fuel ratio, EGR valve position, etc. If it comes back on or is still on, let us know what code is pulled from the computer.
I knew one explorer to have the problem you describe. It was a bad coolant temp sensor. It "painted the picture" to the vehicles's computer of the vehicle always being warmed up to operating temperature. I've also seen it the other way around, where the vehicle would idle extremely high, especially when warmed up because a bad coolant temp sensor read the vehicle as always being cold.
The check engine light is NOT the ultimate diagnostic tool, but in this case it seems to be trying to tell you something. Before you replace anything, pull the codes, see what they have to say, and start there. I hope this helps.
Jan 15, 2007 at 3:47 PM
Suggested Repair
Scan the computer for diagnostic trouble codes before replacing any parts. A similar Explorer with this hard-start symptom had a bad coolant temperature sensor that made the computer think the engine was always warm. Use the codes to identify the failing emission component or sensor.
Conversation Summary
The owner of a 2000 Ford Explorer with a 4.0L V6 reports long morning starts that require pumping and holding the accelerator, even in good weather. Once started, the truck runs well. The check engine light is on, but a paid diagnostic did not explain it. The expert says the light indicates a stored fault and recommends retrieving the codes before replacing parts. A similar Explorer had a faulty coolant temperature sensor that made the computer think the engine was always at operating temperature.
