2000 Ford Explorer
LOSTIME08
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 168,000 MILES
The check engine light came on and when engine is under load such as highway it will not accelerate when you give it throttle it spits sputters until you let off throttle the engine codes are P1131 P1150 P1151 PO171 PO174 Which all seen to indicate the system is running lean is there some common reason for this like a sensor that will cause these problems or where do I start to find the problem
Saturday, October 16th, 2010 AT 5:06 PM
Lean fuel condition could be caused by one of the following below:
1. Vacuum leaks
2. EGR and PCV valve.
3. Low fuel pressure.
4. Dirty fuel injectors.
5. Mass Air Flow Sensor.
6. Oxygen Sensor.
Saturday, October 16th, 2010 AT 7:39 PM
