2000 Ford Explorer
FORD NUMBER ONE
  • 2000 FORD EXPLORER
2000 Ford Explorer
how to remove window run to more easily exchange exterior door handle.
Tuesday, June 1st, 2010 AT 7:04 PM
  • 109,885 POSTS
You need to remove the interior door panel for both. First, after the panel is off, the handle is bolted on. Just remove the linkage and bolts and remove and replace it. Next, I can't tell you about the window. After things are apart, check to see if anything is out of alignment.
Wednesday, June 2nd, 2010 AT 7:10 AM
