Fuel pressure specifications
CBELCHER2308
  • 5 POSTS
Also when I put it in gear to take off it wants to die and if you rev it up wile in parked it chockes out and tries to die
Tuesday, April 16th, 2019 AT 6:41 PM (Merged)
Check the fuel pressure, yours is low
1992 FUEL PRESSURE SPECIFICATIONS (TRUCKS - GASOLINE)
EngineKOER psi (kg/cm2 )KOEO psi (kg/cm2 )
4.9L EFI45-60 (3.2-4.2)50-60 (3.5-4.2)
All Others30-45 (2.1-3.2)35-45 (2.5-3.2)
KENTGADAMS
  • 1998 FORD EXPLORER
  • 6 CYL
  • 106,000 MILES
The other day I went on an errand (10 miles). Came home and decided to go on another short errand! When I tried to start th Explorer it acted as is if it were fllooded and wouldn't start! After 3-5 attempts it started! I ran my errand and was ready to head home when I had the same problem! This time it took 10-15 attempts (pausing between attempts) In 30 minutes it started! When I got back home a neighbor of mine said I have a "fuel pump" problem! Please advise!
  • 109,885 POSTS
Hi:
It could be a fuel pump problem. You need to check pressure. Go to the site listed below. A video will show you how to do it.:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Most nationally recognized parts stores will lend or rent the pressure gauge to you.
Let me know the results. If the pump seems good, we'll move on to other things.
CBELCHER2308
  • 5 POSTS
Mine is a 4.0 and the most its putting is 20psi
Sounds like a weak fuel pump that needs replacing-
CBELCHER2308
  • 5 POSTS
I have put 3 pumps in they work great for 3 or 4 days then start gettn week. What could cause this?
Check the power at the fuel pump connector could be a voltage drop problem and then get back with me-
