1992 Ford Explorer FUEL PUMP
257,000 MILES • 6 CYL • 2WD • MANUAL
JERRY L. MCELWRATH
When I check fuel pressure which is suppose to be 39 to 40 psi and which it is when I turn key on but when I start engine it drops to 30. Is this norm?
Jan 18, 2009 at 3:48 AM
  • 75,988 POSTS
What liter engine is this? there's different specs for a given engine liter on 6 cyl.
Jan 18, 2009 at 5:53 AM
  • 75,988 POSTS
Please! stay in your original post
4.0L
Your okay with the 30psi but why are you checking it?
Jan 18, 2009 at 6:28 AM
JERRY L. MCELWRATH
[quote:332ca16a89="rasmataz"]Please! stay in your original post
4.0L
Your okay with the 30psi but why are you checking it?[/quote:332ca16a89] checking fuel pump to see if bad loss of power
Jan 18, 2009 at 6:38 AM
  • 75,988 POSTS
Losing power could be anything within the engine management system. Do you have a check engine light?
Jan 18, 2009 at 7:10 AM
