1998 Ford Explorer 1998 Ford Explorer O2 Bank 2 Sensor 1 Lo
BIGKAT66
  • 1998 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 112,000 MILES
I have a check engine light on. I checked the code and was told it was the o2 bank 2 sensor 1. It has 4 o2 sensors. Two before and two after the cat. Converter. Can you tell me which o2 sensor this is?
Thanks!
Thursday, April 8th, 2010 AT 8:59 PM
  • 109,885 POSTS
Driver's side before the catalytic converter. Before you replace it, you might want to also make sure the wires are not chaffed / shorted or the connector accidnetally disconnected. It happens and would be a free fix rather than a 75.00 sensor.
Let me know what you find.
Thursday, April 8th, 2010 AT 10:08 PM
