1998 Ford Explorer oxygen sensor
133,000 MILES • 6 CYL • 2WD • AUTOMATIC
USPOPJW
My explorer runs fine but after it is turned off and I restart the engine approx 30 to 60 minutes later, the vehicle does not idle well and will stall. If I give it gas it runs fine and after a few mintues, the vehicle idles normally. Could this be the oxygen sensor? If not, any suggestions? The engine light has not come on.
Jan 13, 2008 at 10:48 AM
BLACKOP555
  • 10,386 POSTS
More then likely it isnt, you should clean your throttle body, egr and check your IAC module.
Jan 13, 2008 at 10:57 AM
