When the explorer sits for approx. 1/2 hr. it will not start . It appears that it is not getting gas because if given a shot of ether it starts. Once running it runs fine. It also starts easily cold and if started within a few minutes. I have changed air filter,cleaned throttle body,plugs,wires, coolant temp. sensor, oxygen sensors, and cleaned the egr. valve to no avail. Any suggestions?
Jan 27, 2008 at 12:25 PM
