HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1998 Ford Explorer
PISTONLEE36
MEMBER
1998 FORD EXPLORER
1998 Ford Explorer
If one replaces the fuel pump, Does the on-board computer need to be reprogram at the dealership?
Friday, April 3rd, 2009 AT 9:49 AM
BLACKOP555
MECHANIC
No. You just need to put it in and crank the engine to get the fuel a flowing.
SPONSORED LINKS
Sunday, April 5th, 2009 AT 9:21 AM
PISTONLEE36
MEMBER
Thank you !
Tuesday, April 7th, 2009 AT 9:47 AM
BLACKOP555
MECHANIC
No problem.
If you need further help post back!
Make sure you dont pinch any of the wires when putting it back on.
Tuesday, April 7th, 2009 AT 6:29 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
Fuel Pump Replacement?
New Fuel Pump Shuts Off 2 Seconds After It Turns On. I Replaced Old One And Also Strainer. Do I Have To Completely Install Tank With All...
Asked by
mannyfrisco10
1 ANSWER
1 IMAGE
1998
FORD EXPLORER
GUIDE
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
Haveing Problems Starting So Got It Checked Was Told...
Haveing Problems Starting So Got It Checked Was Told It Was The Fuel Pump Because When U Spray Starting Fluid In It, It Stayed On As Long As...
Asked by
tony ramos
1998
FORD EXPLORER
1998 Ford Explorer Sometimes It Will Start And...
It Will Turn Over But Will Not Fire Off. Lastnite It Started Fine And Around Lunch Time It Just Will Not Start. This Problem Happened About...
Asked by
2DVS
1 ANSWER
1998
FORD EXPLORER
Can Changing A Fuel Pump Take Out The Instrument...
Can Changing A Fuel Pump Take Out The Instrument Cluster
Asked by
ksl
1997
FORD EXPLORER
1996 Ford Explorer How Can I Change The Feul Pump
Engine Mechanical Problem 1996 Ford Explorer 6 Cyl Four Wheel Drive Automatic My Ford Explorer Won.T Start, The Fuel Pump Is Defect...
Asked by
thewanderer00
1996
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
Engine Not Starting
How to fix an engine that wont start
Online car repair manuals
