1997 Ford Explorer Seat Belt Uncoupling
FORDMARK
My seat belt seems to be uncoupling on its own. I have the Eddie Bauer edition and It looks like I have to take out the console to get to the bolt for the seat belt. The seat belt is attached to the seat rail itself. Is there another way to replace this seat belt?
Mar 26, 2007 at 5:50 AM
MERLIN2021
  • 17,250 POSTS
First off seat belts themselves are real stupid. unless it is cut or badly frayed do not change it! look instead to the control mod for the seat belt, it has gone even dumber!
Mar 26, 2007 at 10:12 AM
Suggested Repair
Do not replace the seat belt unless it is cut or badly frayed. Inspect the seat belt control module instead, as that is the more likely cause of the belt releasing on its own.
Conversation Summary
The owner of a 1997 Ford Explorer Eddie Bauer says the seat belt uncouples by itself and asks whether it can be replaced without removing the console, since the belt is bolted to the seat rail. The expert advises against replacing the belt unless it is cut or badly frayed and recommends checking the seat belt control module.
